Technical advice
Need some technical help? Our handy guides can solve your problems
Read our guidesCheck our advice for tips and checks to keep you vehicle running smoothly whilst out and about on your holidays. Don’t forget, you can always call our technical advice line for help when at home or away.
Clean your spare wheel regularly
If you have an underslung spare wheel carrier, release it and clean/lubricate the sliding parts from time to time… if not it will inevitably be jammed solid the first time you really need to get at it.
Use a bike pump to keep your tyres topped up
If your caravan or motorhome tyres need very high inflation pressures, use a bicycle ‘track pump’ to put the last few pounds in as an alternative to an expensive heavy duty compressor.
Switch to LED bulbs
If you’re staying off-grid, switch interior 12V builds to LED ones to reduce power usage.
Lubricate your awning
Make it easier to fit the awning by lubricating the awning channel with silicone spray or silicone furniture polish.
Make yourself a noseweight gauge
If you don’t have a noseweight gauge, a set of bathroom scales and a suitable length of wood will usually give a very accurate indication.
Check all your lights and tyres before setting off
Get used to having a ‘pre-flight checks’ routine before setting off – always check roof lights are closed, road lights are working etc. in the same order to avoid missing something.
Protect your mains hook-up lead
Always fully uncoil your mains hook-up lead when in use to prevent it overheating. Lay it out in large loops if necessary. Never leave the lead connected and on the pitch if heading out for the day in a motorhome – use a ‘pitch occupied’ sign instead.
Look after your tow ball
Clean the paint finish off the head of a new tow ball before first use – if not, you’ll damage the friction pads in a hitch stabiliser.
