Pencil gauge
‘Pencil’ type gauges are cheap and small, but may be awkward to read, have a limited range (usually no more than 50psi) and limited accuracy and durability.
If you’re thinking of buying new wheels for your caravan, stick to specialist retailers. Be very sceptical of second-hand wheels, unless certain they are in good condition and of an appropriate specification.
When buying alloy wheels, make sure you buy ones specifically designed for caravans, rather than trying to find car ones with the correct characteristics. Any make of tyre which has the correct service description and is Type Approved for use in Europe is acceptable.
If you’re thinking of buying new tyres, shop around; it may be worth consulting our guide on choosing the right tyres if you'd like further information. Prices vary hugely.
If buying more than one tyre, get a price initially for just one, and see if a discount (or free valves and fitting etc) is then available if buying more than one. Make sure you know exactly what specification you want, as many retailers are not very knowledgeable about caravan tyres.
The choice of tyre make is less critical than for motor vehicles, but quality does still vary, usually in proportion to price. Tyre brands can be loosely divided into three categories:
Digital gauges are also small and cheap, but are easier to read and generally reliable. Accuracy is usually reasonable. Often read to 60psi or more.
Dial gauges come in a range of sizes (larger ones being easier to read) and are most likely to be really accurate, especially if marked with a relevant standard, such as BS 4613.
Contact details
Do you have a list of approved caravan and motorhome repairers?
Are caravans legally required to have an MOT or a service?
