This advice does not apply to unbraked trailers up to 750kg GVW which are required by law to have the use of a secondary coupling.
A secondary coupling should keep the trailer attached to its towing vehicle even if its main coupling becomes separated.
The guidance set out on this page is provided for general guidance purposes only, and does not purport to be legal advice or a definitive interpretation of the law.
